Optimus M FAQ's
Status
Not open for further replies.
D-U-R-X
turbo drinker
1. General Android phone FAQ's?
2. How can I improve my battery life?
3. Are there any Optimus M Tips & Tricks?
4. What are the known problems with the Optimus M?
5. Forum related questions.
6. What is root?/What does being rooted mean?
7. How can I check for updates for my LG?
Q: General Android phone FAQ's?
A: Here is a thread on general Android Phone FAQ's
Q: How can I improve my battery life?
A: First, check these posts: Poor Battery Life? and increase battery life/ widget ideas You do not have to follow all of the tips/suggestions, but the advice is sound and will help. Smartphones operate on a sort of spectrum. On one end you could put battery life, on the other end all those options like wifi/3g/sync (among other things). If you want great battery life you can't have those on all the time. If you want those on all the time, you won't get great battery life. It is best to find the compromise that works best for you and what you want most out of your phone.
Q: Are there any Optimus M Tips & Tricks?
Q: What are some of the problems people have with their Optimus M?
Here is a link to the Optimus M All Things Root Guide sticky
Q: How can I check for updates for my LG?
A: Here is a thread detailing that
Status
