Root optimus m seriously messed up HELP!
on my optimus m i rooted it with gingerbreak, then uninstalled some bloatware and by mistake i deleted contacts apk, and the dialer apk. ive been trying to downgrade, restore, everything i could find online and nothing worked, on lgnpst i always get a error 1712 after installing the 3.0 components. so i found i thread with original apks for the optimus, found every one i needed, installed them with root explorer and rebooted, still not there and at this point i had no service...i went into settings to see if i turned mobile network off by mistake and it wouldnt let me enter, i had to force close it so i decided to deleted the settings and install the one from the thread, rebooted and now im in a bootloop on the android screen, tried recover (home, volume down, and power) shows an android logo with a box then goes back into bootloop, cant get into emergency mode, BUT my computer does recognize my phone when i plug it in, if anyone can help me out or even use team viewer to controll my computer to fix my phone id really appreciate it, i use my phone for work EVERY day. ill even send some money through paypal if you can fix it. ill be up all night so please pm me if you can help!
Try this: http://www.androidforums.com/optimu...nt-easily-replace-system-app-you-deleted.html
Tell me if you have any problems.
