TVCCS
Here are some of the better choices I've seen in Car Mounts...feel free to add your own...of course you can use universal mounts as well.
Navigational Mount for LG Vortex - Verizon
Fits the V (without a case) perfectly, very stable, well made, large suction cup, low profile behind phone, phone can be mounted vertically or horizontally...does not launch Car Home app on V insertion. This mount does not have the integrated power Verizon claims, rather you plug in a charger as needed to the phone's exposed jack, as shown in the picture.
LG Vortex Navigational Mount
Griffin WindowSeat Mobile HandsFree Car Kit
Maybe the best all-in-one solution for the Optimus...will handle the phone without a case or in a non-button case, as long as it's not too thick. Comes with both dash and windshield mounts, a 1000mah charger, and a unique Aux cable that has a small built-in mic, allowing for audio playback from the V while connected to a car stereo with an aux jack - can also be used with a cassette adapter with a 3.5mm coupler. The mic's quality for phone calls and voice commands, especially at highway speeds, may be a concern for some, as it doesn't have the noise reduction features of better headset mics.
Griffin Technology: WindowSeat Mobile HandsFree Car Kit - for smartphones, iPhone, and iPod
Also available without the charger:
Griffin Technology: WindowSeat HandsFree - Windshield or dash mount with hands-free mic
A well done video review from Geekanoids:
http://www.youtube.com/watch?v=DK9AOd51q6o
Pro.Fit International Express Holder EM-1224
The only holder I've found that will handle a button case like the Body Glove, other than the kind that stick on a dash. The button holder EM-1224 can be combined with either a LoBoy dash mount (LB-600) or a 7" WindowMate (WM-36) arm for a windshield. They also make other holders and mounts that can be used with the Optimus, as well as numerous custom car, bike, and motorcycle mounts. The WM-36 will vibrate a little (at least it has for me) when mounted on a windshield in use with the EM-1224 and the Body Glove case. I find it acceptable, but cars with vibration issues will likely suffer more.
Pro.Fit International - Mounting solutions for Cell Phones, iPhones and GPS
The EM-1224 and the WM-36 can also be found as the WM-36EXP, which preassembles the two pieces.
http://cgi.ebay.com/Pro-Fit-Interna...ltDomain_0&hash=item51928bbea6#ht_2001wt_1082
) and it works perfectly. In fact I can adjust it to hold just about anything *cough* my old iPod *cough*
