dukeboy666
You can play Order & Chaos on the Warp.(Your Warp must be rooted)
Step 1)Get a build prop editor, you can find one in the market.
Step 2)Open up the build prop in the editor.(Make sure you make a back up of your build prop first.)
Step 3)Make changes in the build prop to look like this:
ro.product.model=Optimus 2X
ro.product.model.internal=
ro.product.brand=lge
ro.product.name=lge_star
ro.product.device=p990
ro.product.board=p990
Step 4)Go to marker and you should be able to download it.
Step 5)Install, and then let it download the needed files.
Step 6)You will need a Gameloft accout to log into the game.
Step 7)Load up the game and enjoy.
(By doing this the wifi will not work)
So to get wifi to work again.
Step 1)After doing everything above to get the game.
Step 2)Go back to build prop editor, and restore you backup build prop
Step 3)Go back to build prop editor(no need to backup, for you have already backed it up befor) Edit build prop and only change:
ro.product.model=Optimus 2X.
And you will be able to play Order & Chaos, and still have wifi.
