I am using the bookmarks widget, list view. I like it but would like to change the order the bookmarks appear. I did not any options for doing so. Is there a way to do this?
I don't see a sort option while in the browser. Not sure where it is. I'm using the stock "internet" application that came with the EVO. When on a page I click menu and see back, forward, add bookmark, bookmarks, windows and more. Clicking more doesn't show a "sort" option either. Where is it?
EDIT: Nevermind, found it. Thanks. Gives you the ability to sort by newest, most used and alphabetical. No manual organization however.
You can sort by:
1.) newest
2.) mostly used
3.) alphabetical
open the brower and then follow these steps to do the above:
menu>navigate>menu>sort by
There isn't any way to sort them then the above in the list format. You can however creat shortcuts for each site and put them as icons on your phone or you could put them all in a folder. Either way, you can organize those however you want.
