Help Orientation Sensor not working
RussWWFC
Any idea on how to get the screen orientation sensor working. Not worked for a while actually, had it rooted then changed it back.
I use Launcher Pro plus if that makes any difference
Oh.. and another thing.. I am still stuck on 1.32.405.6
I did a RUU flash to get it back to normal (not rooted) and it has updated once. Now it's saying there are no updates for the phone
They pulled the 2.2.1 (172.xxx.x) update.
GB will be along this month they say...
Thanks guys. That's cleared up the worry that I won't get any more updates post root. And it was the setting, ticking the box fixed it, suprised it wasn't on by default
