Does anyone have the original droid 3 extended battery?...
How much does it really extended life?...
And am I able to use the stock cover.. I heard it fits?
Best thing I have ever spent my money on.
So should I just buy the battery and not the door?
Does anyone have the original droid 3 extended battery?... How much does it really extended life?... And am I able to use the stock cover.. I heard it fits?
I bought the extended battery a few weeks after getting my D3. Typically, I get more than 24 hours to a charge. That's with quite a bit of texting, phone calls and surfing. The battery comes with a new back cover for the phone. I can't really tell any difference in the size, but the phone is a tad bit heavier.
I'd highly recommend the extended battery. I took my phone off the charger this morning, made calls, played some games, surfed a bit, and have had wifi on all day. The phone is still at 80%. I won't charge it until sometime tomorrow (I have a desk dock at my office, because I play Pandora all day at work).
Well to say I'm a heavy user is an under statement at the moment I charge my galaxy s 2 maybe three times a day... This is what I'm thinking either buy the hdmi oem verizon dock and the extended battery how much does it thicken the phone? .. Or buy another stock battery and any old dock that has a extra charging slot behind it and swap batteries? What should I do?
Well, I bought the extended battery and got pretty much the same results as with the original, so I returned it after about a week.
The battery did fit with the original cover, as far as I remember (or was it the hard case that held it in place?).
If there was a good extended, reliable battery, I'd happily buy it. But I'm not spending $50 or so on a battery that hardly makes a difference on my phone.
I still can't believe it...![]()
