It was called "Battery Widget", and I'm 99% sure it was on the phone when I got it. I downloaded another one, because I did not think the original one displayed the current draw/charge, but it actually did. I deleted it this morning by mistake, and cannot seem to find it anywhere. There are a lot of Battery Widgets in the Market, but none are like the one I had.
I dont ever recall having any battery widget on a stock Bionic. If you were coming from a previous droid device it could have transferred over via the Market. When setting up your phone Verizon tech will usually try to install whatever you had in the Market under your google account so it might be something you had in a previous phone.
You may alreeady know ...
If it was purchased and then unistalled ... get onto Market ... list your installed Apps ... scroll to the bottom of the list ... it will list all those you purchased but don't have installed.
... Thom
