Root os crashed
my huawei idoes x5 has crashed when i trying to install clockworkmod recovery while replacing the boot.img file im on gingerbread but the froyo sign come android any android os to reinstall or can i install cynogen mod directly or jelly bean or honey comb any os please help me fasttttt:confused:
[FONT=&quot]Hi savio, Did you follow instructions like the following when you tried to install CWM?[/FONT]
[FONT=&quot]This is done after you Root the phone and before Flashing a ROM.
[/FONT]
[FONT=&quot]
[/FONT]
[FONT=&quot]How to Install ClockWorkMod Recovery on your Huawei Ideos X5 U8800 :[/FONT]
[FONT=&quot]Step 1 :[/FONT]
[FONT=&quot]Step 2 :[/FONT]
  • [FONT=&quot]Now, connect your device to the computer by using a proper data cable.[/FONT]
[FONT=&quot]Step 3 :[/FONT]
  • [FONT=&quot]Copy downloaded recovery package on your phones external memory. Do not extract any files.[/FONT]
[FONT=&quot]Step 4 :[/FONT]
  • [FONT=&quot]Now, turn off your device and boot into fastboot mode.[/FONT]
[FONT=&quot]Step 5 :[/FONT]
  • [FONT=&quot]Go to: Settings > Applications > Untick Fast Boot[/FONT]
[FONT=&quot]Step 6 :[/FONT]
[FONT=&quot]Step 7 :[/FONT]
  • [FONT=&quot]Now, mount /.cust_backup as rw and then copy and replaced the above downloaded recovery files which should have a name like recovery.img to /.cust_backup/image/recovery.img.[/FONT]
[FONT=&quot]Step 8 :[/FONT]
  • [FONT=&quot]ClockWorkMod Recovery successfully installed on your device. You are allowed to install any custom ROM to this device by now.[/FONT]
Note: The hyperlinks probably won't work. Neil.
