Root OTA 2.2 Question
Ok so im confused on a little bit of this. With the ota 2.2 update, does it mean you cant root period? or is it just flash to 2.1?
you absolutely CAN root. but as of right now, you cannot flash back to 2.1 with the sbf method we have been using for the past 6 or so weeks. i am sure there will be a method soon enough, but as of right now, it is not possible once you have installed the leak.
