Root ota notification
Trel
I forgot to disable ota notifications, and now I am getting the 2.1 one. I disabled the cert, but I keep getting the notification,, how can I disable that now?
No, if I had had removed the certs, I wouldn't get them to begin with. I didn't do it in time, there has to be something on the phone I can change to kiill them.
There are good ROMs (great ROMs) available. Why don't you just flash one of them and be done with it? Then it won't be an issue.
That's what I'm encouraging him to do.. Not sure why he's being difficult.
With ROM Manager and Titanium Backup you can flash a different ROM and still have all your programs and data. Takes 15 minutes max.
Agreed. Simple - continue to get annoyed by update messages or move on to something better without the annoyance. Tough choice :confused::confused::confused:
because I spent the last month customizing the phone the way I like it and do not want to use a custom mod. I guess I will ask elsewhere. This has been about as helpful as people who tell me to get a mac when I ask about a PC problem.
Well I am in tears that we let down. Hope you find a solution and a better attitude towards those that are trying to help :D
Look, I'm not trying to have a bad attitude. I'm being told that rather than anyone really helping, I should use a different rom instead.
I can't believe that this is the only way. It had to download something, and that something should be able to be removed.
It's not that I'm having a bad attiude, but I really can't see telling me to use a different rom, as being any more helpful than the mac example.
(If you look at my post history, almost every question I asked had to do with AVOIDING using another rom and doing everything I could with the stock firmware as the base)
(Plus, based on other people's topics: http://androidforums.com/all-things-root-droid/59438-ota-getting-thru-sholesmod.html the rom change wouldn't work anyway )
Guys, I don't want to argue, but I'm with the OP. In this link, in how to disable OTA updates, it says nothing about having to flash a custom ROM to disable OTA.
http://androidforums.com/all-things-root-droid/45764-guide-s-everything-root-related.html
Just that you have to root, and run the commands to rename the files, which will disable OTA updates.
So the real questions are:
1) Did the OP follow these instructions? I assume yes.
2) If yes to number 1, why is this not working for him?
You can disable ota without having a custom ROM. But you do have to go through the root steps.
Thanks,
Joe
You should be able to disable ota without having a custom ROM.
Thanks,
Joe
Joe, you are right. The solution originally provided should have worked. But one thing I and others try to do when something is not working is offer a viable alternative. I have posted questions and although did not get a direct answer, responses were still helpful and I showed my appreciation for the intent. A simple "Hey thanks for trying to help but I really want to do it this way" is fine. A sarcastic "This has been as useful as..." is really unacceptable in the context of this thread.
it's funny, on the other OTA thread right by this one about sholes/DM, I just kind of got pissed off. Sometimes I just gotta hit the 'chill button'.
From the Droidmod forum, as posted in "the other" thread.
"If you installed DroidMod 1.0 via DMUpdater, just accept the VZW OTA 2.1 update. It will boot your Droid and go straight to SPRecovery. Select the Reboot (the 1st option) and you're good to go."
I can confirm it works.
Just make sure you don't accidentally let it skip past recovery and patch your phone. The result will be a mess, I'm sure.
Just keep in mind that with Titanium backup, you can keep all of your programs and all of the data that goes with them. All you would have to do is set up your icons and widgets again.
For the record, I was able to solve my problem by moving the certs files to another directory, rather than just renaming.
This caused a boot loop for me on DM 1.0 when I reboot the phone. It would get to the DroidMod boot screen with the little progress bar, then about 5 seconds later, it would reboot.
Specifically what I did was create a /system/etc/security-old dir, and I moved (mv) the 2 certs files from security to security-old via ADB, then rebooted.
Joe
Joe
I don't know. Leaving them there didn't help, but also I'm not using Droidmod. I'm using the plain OS that I added to myself.
EDIT: I just rebooted mine, with the files not there, and the result is,
removing cacerts.bks prevents my phone from booting, but removing otacerts does not.
Verdict (in my case)
Remove otacerts.zip but leave cacerts.bks
