- Bugless
- Bugged a little bit
- Bug Monster from the Black Lagoon
Mine randomly disconnects calls. It's annoying.
eh HW issues here to and got replacement cupcake. tried to root today via the root thread and got some BS error about xp..... forced dl of ota for now but i really need help rooting and ill pay for it.... err or someone willWhen I had v3 I had:
Browser crashes...that's all I can think of atm.
I got a refurb for hardware (proximity sensor) oh yeah frisco you were in that thread, I ended up getting it after many calls and store visits. So rooted now.
Back on topic, v3 was fine.
ill look into that when im less hammered. lol *beer again* . whew!I tried the root master app too, it wouldn't dl, same problem as you. Just use the script in the SDK method, I think it's from Jcase. Super easy, then you can just flash whatever rom you want, it doesn't need to be one in the master app.
yup, thought i would say yup. had l3 and it happened alotI have the same browser crash problem with v.3
Read, don't post when you're totally buzzed.yup, thought i would say yup. had l3 and it happened alot![]()
I'm going with Bugless, because I don't know if these "bugs" are even issues as they seem to have no adverse effect on the phone and are probably just cosmetic...
1. 50% without signal
2. A weak signal according to the bars, even though my signal is excellent.
3. After using the camera, the battery reading is 96% from the camera.. only way to rid the phone of that reading is by rebooting... though, this is not accompanied by a massive battery drain.
4. Again, according to the battery reading, sometimes the phone won't sleep as awake time is constantly on. The supposed cause is the "Android System"... again, no battery drain
maybe some other stuff, but nothing that is noteworthy, nor causing problems with the phones functionality
"Annoyances" comes to mind.
But I feel that the commonality of your #s 1 and 2 qualify them as true bugs; we're seeing reports of those all over the place. It is obviously a displayed data bug rather than truly having 50% and truly having low signal strength.
But if that data were accurate on those two things alone it would be a deal breaker for me; that would be low quality phone functionality.
