An ounce of caution is worth a pound of cure.![]()
Thank you. Although I have a different phone, I've been seeking this answer. I'll try it out for size.In Root Explorer, did you tap on the "Remount as R/W" at the top? When you're done renaming, you have to tap that button again to remount as R/O.
Rename it to OTAcerts.zip.BAK
