My phone is NOT rooted.
Are there any good keyboard apps you prefer over the stock keyboard for this phone?
Can they be used on a non-rooted phone?
Thanks
I like Swype beta. It can be downloaded from their site. Swiping grows on you. Most if not all keyboard do not require rooting.
What is different from the version that came with the phone?
Swype beta does not require root, the original does because it is a system app. You have to enable "unknown sources" though, in the settings/applications to install the apk from Swype's website.I also use Swype beta, but I think you have to be rooted to use it. It saves your dictionary if you change phones or roms. I've been using it for so long I honestly don't remember the other differences, but I remember loving it after changing from regular Swype. If you don't want to root your phone, try Kii Keyboard.
Swiftkey 3 is an awesome app!!!!SwiftKey 3 https://play.google.com/store/apps/details?id=com.touchtype.swiftkey.phone.trial
The free version on the Play Store is a one month trial.
It is worth the cost for the full version.
It's awesome.
The official stock 4.2 keyboard is available on the play store too. It's has the swype-like input option. It's called "google keyboard".
OP said they're running stock GB. Google Keyboard is for 4.0+.![]()
