Help Other reasons why battery issue needs fix
Status
Not open for further replies.
Moment
Member
Ok so I know many are having battery issues. You, like me, probably have more battery life than you think. This is because the application layer of the phone is not receiving the hardware layer's data correctly (hold talk button, end call button, and middle button upon starting up your turned-off phone, this boots in test mode which shows you hardware layer battery power, aka the correct battery life estimate). It's causing another problem because some applications can't be run when the phone THINKS it's about to die.
There has to be a workaround for this. Does anyone know?
and you couldn't post this in the big battery quirk thread, why? There's only 3 other battery threads on the first page. Seriously...
Status
