Root [OUDHS] CM-10 for Galaxy Reverb from Jimmy422 and Interloper
xInterlopeRx
MAKE A BACKUP FIRST!
Ok, since the other thread had a misleading title, and because we all have something to tell the grandkids about I went ahead and started a thread for the Samsung Galaxy Reverb.
[rant]This thread should be for you, the user, to ask questions concerning the development of CM-10 for YOUR phone. This is a development thread, so please try to focus the comments on bugs, reports, logs, etc. There is a thread in the general section for other discussion about the device. I don't want to be a forum moderator but I also don't want to be swimming through extraneous posts trying to find important information.[/rant]
That being said Jimmy422 has started a github for the device and that is right here.
I also have a github for the device and that link is in my signature, as is a link to use webchat and connect with me personally. Jimmy422 does enter the chat, but seldom stays long. Any message with the name 'interloper' in it will alert me and I will get the message. Please, don't be shy. Ask what you want to ask. As long as you don't want to date either of us, it'll be ok.
Lets start off with a file created today by bully the buildbot, AKA, my computer:
I was told this file failed to flash, but I don't know why yet. Maybe someone can figure it out for us before I can get to it.
Wait, Martinez is on the other thread so I gotta cut this short, bye!
Hey, here is the test build for the day. By downloading this you agree that I will not be held responsible for anything happening to your device. MAKE A BACKUP FIRST! Then, you mush also agree to read how to use adb logcat and adb shell to provide logs on what is happening so I can make the changes for tomorrows' build.
Im not really sure how to use github, but let me just ask: Do we have a bootable cm10 or is it still to early in dev?
Thanks for all your work, we all appreciate it :)
We do not yet have a booting cm-10. It should be booting in the next few days, then on to fixing everything that inevitably needs fixing. so, if the dev cycle was a clock, we're just past midnight...
I'll be posting a link in a few minutes that will (should) flash and hopefully we can start collecting logs and last_kmsg from the kernel.
If it flashes I can help you out with logs and what not
Did either of you try ABD perchance? I have a partially boot Galaxy Victory that behaves like a sucking chest wound but it gives me a logcat for a few seconds and I can at least get some clues as to the internal injuries. Please try to give me as much information as possible about the experience and the device, because without it I can't do much but guess. Also, I need a stock boot.img for the ramdisk. It can be done with ADB OR I think you can get it from a backup.
Here's the boot image:
boot.img
Also I think you're using an incorrect defconfig file for the kernel. The icon00 is something else, because if you compare it with the one on the phone it's completely different. I'll recompile with the one pulled from the phone and see if that makes a difference.
I did not...I current currently am out of a computer because I left it in my girl's car...whoops!
Good news guys! With PlayfulGod's help we got ADB working! I have no idea what to make of it, but it's definite progress. It's showing a (corrupted) initlogo.rle and bootlooping.
Here's the results of adb logcat
Code:
--------- beginning of /dev/log/main
F/libc    (  122): Fatal signal 11 (SIGSEGV) at 0x0007d9d0 (code=1)
I/logwrapper(  121): /system/xbin/run-parts terminated by signal 11
F/libc    (  128): Fatal signal 11 (SIGSEGV) at 0x00005db0 (code=1)
F/libc    (  131): Fatal signal 11 (SIGSEGV) at 0x00002e50 (code=1)
F/libc    (  130): Fatal signal 11 (SIGSEGV) at 0x00001ea0 (code=1)
F/libc    (  133): Fatal signal 11 (SIGSEGV) at 0x00001e84 (code=1)
F/libc    (  136): Fatal signal 11 (SIGSEGV) at 0x00003dec (code=1)
F/libc    (  140): Fatal signal 11 (SIGSEGV) at 0x0007d9d0 (code=1)
F/libc    (  150): Fatal signal 11 (SIGSEGV) at 0x0007d9d0 (code=1)
E/ThermalDaemon(  157): Thermal daemon started
I/rmt_storage(  156): rmt_storage user app start.. ignoring cmd line parameters
I/rmt_storage(  156): rmt_storage open success
E/ThermalDaemon(  157): Threshold 0 Action[0] : none
E/ThermalDaemon(  157): Threshold 1 Action[0] : none
E/ThermalDaemon(  157): Threshold 2 Action[0] : none
E/ThermalDaemon(  157): Threshold 0 Action Info[0] : 768000.000000
E/ThermalDaemon(  157): Threshold 1 Action Info[0] : 368640.000000
E/ThermalDaemon(  157): Threshold 2 Action Info[0] : 245760.000000
E/ThermalDaemon(  157): Number of cpus :1
I/rmt_storage(  156): 3 supported partitions found
E/ThermalDaemon(  157): No rules to monitor sensor 'XO_THERM' disabled: 0 num_thresholds: 0
E/ThermalDaemon(  157): No rules to monitor sensor 'XO_THERM_GPS' disabled: 0 num_thresholds: 0
E/ThermalDaemon(  157): No rules to monitor sensor 'POP_MEM_TZ' disabled: 0 num_thresholds: 0
F/libc    (  171): Fatal signal 11 (SIGSEGV) at 0x00001e84 (code=1)
F/libc    (  168): Fatal signal 11 (SIGSEGV) at 0x00001ea0 (code=1)
F/libc    (  172): Fatal signal 11 (SIGSEGV) at 0x00003dec (code=1)
F/libc    (  169): Fatal signal 11 (SIGSEGV) at 0x00002e50 (code=1)
F/libc    (  166): Fatal signal 11 (SIGSEGV) at 0x00005db0 (code=1)
F/libc    (  180): Fatal signal 11 (SIGSEGV) at 0x00001e84 (code=1)
F/libc    (  181): Fatal signal 11 (SIGSEGV) at 0x00003dec (code=1)
F/libc    (  178): Fatal signal 11 (SIGSEGV) at 0x00002e50 (code=1)
F/libc    (  177): Fatal signal 11 (SIGSEGV) at 0x00001ea0 (code=1)
F/libc    (  175): Fatal signal 11 (SIGSEGV) at 0x00005db0 (code=1)
F/libc    (  189): Fatal signal 11 (SIGSEGV) at 0x00001e84 (code=1)
F/libc    (  190): Fatal signal 11 (SIGSEGV) at 0x00003dec (code=1)
F/libc    (  186): Fatal signal 11 (SIGSEGV) at 0x00001ea0 (code=1)
F/libc    (  187): Fatal signal 11 (SIGSEGV) at 0x00002e50 (code=1)
F/libc    (  184): Fatal signal 11 (SIGSEGV) at 0x00005db0 (code=1)
F/libc    (  200): Fatal signal 11 (SIGSEGV) at 0x00001e84 (code=1)
F/libc    (  198): Fatal signal 11 (SIGSEGV) at 0x00002e50 (code=1)
F/libc    (  201): Fatal signal 11 (SIGSEGV) at 0x00003dec (code=1)
F/libc    (  197): Fatal signal 11 (SIGSEGV) at 0x00001ea0 (code=1)
F/libc    (  195): Fatal signal 11 (SIGSEGV) at 0x00005db0 (code=1)
F/libc    (  209): Fatal signal 11 (SIGSEGV) at 0x00001e84 (code=1)
F/libc    (  210): Fatal signal 11 (SIGSEGV) at 0x00003dec (code=1)
F/libc    (  206): Fatal signal 11 (SIGSEGV) at 0x00001ea0 (code=1)
F/libc    (  204): Fatal signal 11 (SIGSEGV) at 0x00005db0 (code=1)
F/libc    (  218): Fatal signal 11 (SIGSEGV) at 0x00001e84 (code=1)
F/libc    (  219): Fatal signal 11 (SIGSEGV) at 0x00003dec (code=1)
F/libc    (  216): Fatal signal 11 (SIGSEGV) at 0x00002e50 (code=1)
F/libc    (  215): Fatal signal 11 (SIGSEGV) at 0x00001ea0 (code=1)
F/libc    (  213): Fatal signal 11 (SIGSEGV) at 0x00005db0 (code=1)
F/libc    (  227): Fatal signal 11 (SIGSEGV) at 0x00001e84 (code=1)
F/libc    (  225): Fatal signal 11 (SIGSEGV) at 0x00002e50 (code=1)
F/libc    (  228): Fatal signal 11 (SIGSEGV) at 0x00003dec (code=1)
F/libc    (  224): Fatal signal 11 (SIGSEGV) at 0x00001ea0 (code=1)
F/libc    (  222): Fatal signal 11 (SIGSEGV) at 0x00005db0 (code=1)
F/libc    (  237): Fatal signal 11 (SIGSEGV) at 0x00003dec (code=1)
F/libc    (  234): Fatal signal 11 (SIGSEGV) at 0x00002e50 (code=1)
F/libc    (  233): Fatal signal 11 (SIGSEGV) at 0x00001ea0 (code=1)
F/libc    (  231): Fatal signal 11 (SIGSEGV) at 0x00005db0 (code=1)
F/libc    (  243): Fatal signal 11 (SIGSEGV) at 0x00002e50 (code=1)
F/libc    (  245): Fatal signal 11 (SIGSEGV) at 0x00001e84 (code=1)
F/libc    (  246): Fatal signal 11 (SIGSEGV) at 0x00003dec (code=1)
F/libc    (  242): Fatal signal 11 (SIGSEGV) at 0x00001ea0 (code=1)
F/libc    (  240): Fatal signal 11 (SIGSEGV) at 0x00005db0 (code=1)
F/libc    (  254): Fatal signal 11 (SIGSEGV) at 0x00001e84 (code=1)
F/libc    (  252): Fatal signal 11 (SIGSEGV) at 0x00002e50 (code=1)
F/libc    (  255): Fatal signal 11 (SIGSEGV) at 0x00003dec (code=1)
F/libc    (  251): Fatal signal 11 (SIGSEGV) at 0x00001ea0 (code=1)
F/libc    (  249): Fatal signal 11 (SIGSEGV) at 0x00005db0 (code=1)
F/libc    (  263): Fatal signal 11 (SIGSEGV) at 0x00001e84 (code=1)
F/libc    (  264): Fatal signal 11 (SIGSEGV) at 0x00003dec (code=1)
F/libc    (  261): Fatal signal 11 (SIGSEGV) at 0x00002e50 (code=1)
F/libc    (  260): Fatal signal 11 (SIGSEGV) at 0x00001ea0 (code=1)
F/libc    (  258): Fatal signal 11 (SIGSEGV) at 0x00005db0 (code=1)
F/libc    (  272): Fatal signal 11 (SIGSEGV) at 0x00001e84 (code=1)
F/libc    (  273): Fatal signal 11 (SIGSEGV) at 0x00003dec (code=1)
F/libc    (  270): Fatal signal 11 (SIGSEGV) at 0x00002e50 (code=1)
F/libc    (  269): Fatal signal 11 (SIGSEGV) at 0x00001ea0 (code=1)
F/libc    (  267): Fatal signal 11 (SIGSEGV) at 0x00005db0 (code=1)
F/libc    (  281): Fatal signal 11 (SIGSEGV) at 0x00001e84 (code=1)
F/libc    (  279): Fatal signal 11 (SIGSEGV) at 0x00002e50 (code=1)
F/libc    (  282): Fatal signal 11 (SIGSEGV) at 0x00003dec (code=1)
F/libc    (  278): Fatal signal 11 (SIGSEGV) at 0x00001ea0 (code=1)
F/libc    (  276): Fatal signal 11 (SIGSEGV) at 0x00005db0 (code=1)
F/libc    (  290): Fatal signal 11 (SIGSEGV) at 0x00001e84 (code=1)
F/libc    (  288): Fatal signal 11 (SIGSEGV) at 0x00002e50 (code=1)
F/libc    (  291): Fatal signal 11 (SIGSEGV) at 0x00003dec (code=1)
F/libc    (  285): Fatal signal 11 (SIGSEGV) at 0x00005db0 (code=1)
F/libc    (  287): Fatal signal 11 (SIGSEGV) at 0x00001ea0 (code=1)
F/libc    (  300): Fatal signal 11 (SIGSEGV) at 0x00003dec (code=1)
F/libc    (  297): Fatal signal 11 (SIGSEGV) at 0x00002e50 (code=1)
F/libc    (  299): Fatal signal 11 (SIGSEGV) at 0x00001e84 (code=1)
F/libc    (  296): Fatal signal 11 (SIGSEGV) at 0x00001ea0 (code=1)
F/libc    (  294): Fatal signal 11 (SIGSEGV) at 0x00005db0 (code=1)
F/libc    (  308): Fatal signal 11 (SIGSEGV) at 0x00001e84 (code=1)
F/libc    (  309): Fatal signal 11 (SIGSEGV) at 0x00003dec (code=1)
F/libc    (  306): Fatal signal 11 (SIGSEGV) at 0x00002e50 (code=1)
F/libc    (  305): Fatal signal 11 (SIGSEGV) at 0x00001ea0 (code=1)
F/libc    (  303): Fatal signal 11 (SIGSEGV) at 0x00005db0 (code=1)
I/rmt_storage(  156): rmt_storage open event: handle=1
I/rmt_storage(  156): Opened /boot/modem_fs1
I/rmt_storage(  156): rmt_storage events processing done
I/rmt_storage(  156): rmt_storage send user data event
I/rmt_storage(  156): rmt_storage client thread started
I/rmt_storage(  156): rmt_storage open event: handle=2
I/rmt_storage(  156): Opened /boot/modem_fs2
I/rmt_storage(  156): rmt_storage write event
I/rmt_storage(  156): unblock rmt_storage client thread
I/rmt_storage(  156): rmt_storage fop(1): bytes transferred = 3145216
I/rmt_storage(  156): rmt_storage fop(1): bytes transferred = 512
F/libc    (  317): Fatal signal 11 (SIGSEGV) at 0x00002e50 (code=1)
F/libc    (  320): Fatal signal 11 (SIGSEGV) at 0x00003dec (code=1)
F/libc    (  316): Fatal signal 11 (SIGSEGV) at 0x00001ea0 (code=1)
F/libc    (  314): Fatal signal 11 (SIGSEGV) at 0x00005db0 (code=1)
F/libc    (  328): Fatal signal 11 (SIGSEGV) at 0x00001e84 (code=1)
F/libc    (  326): Fatal signal 11 (SIGSEGV) at 0x00002e50 (code=1)
F/libc    (  329): Fatal signal 11 (SIGSEGV) at 0x00003dec (code=1)
F/libc    (  325): Fatal signal 11 (SIGSEGV) at 0x00001ea0 (code=1)
F/libc    (  323): Fatal signal 11 (SIGSEGV) at 0x00005db0 (code=1)
F/libc    (  337): Fatal signal 11 (SIGSEGV) at 0x00001e84 (code=1)
F/libc    (  338): Fatal signal 11 (SIGSEGV) at 0x00003dec (code=1)
F/libc    (  334): Fatal signal 11 (SIGSEGV) at 0x00001ea0 (code=1)
F/libc    (  335): Fatal signal 11 (SIGSEGV) at 0x00002e50 (code=1)
F/libc    (  332): Fatal signal 11 (SIGSEGV) at 0x00005db0 (code=1)
F/libc    (  346): Fatal signal 11 (SIGSEGV) at 0x00001e84 (code=1)
F/libc    (  344): Fatal signal 11 (SIGSEGV) at 0x00002e50 (code=1)
F/libc    (  347): Fatal signal 11 (SIGSEGV) at 0x00003dec (code=1)
F/libc    (  343): Fatal signal 11 (SIGSEGV) at 0x00001ea0 (code=1)
F/libc    (  341): Fatal signal 11 (SIGSEGV) at 0x00005db0 (code=1)
F/libc    (  355): Fatal signal 11 (SIGSEGV) at 0x00001e84 (code=1)
F/libc    (  352): Fatal signal 11 (SIGSEGV) at 0x00001ea0 (code=1)
F/libc    (  353): Fatal signal 11 (SIGSEGV) at 0x00002e50 (code=1)
F/libc    (  356): Fatal signal 11 (SIGSEGV) at 0x00003dec (code=1)
F/libc    (  350): Fatal signal 11 (SIGSEGV) at 0x00005db0 (code=1)
F/libc    (  364): Fatal signal 11 (SIGSEGV) at 0x00001e84 (code=1)
F/libc    (  362): Fatal signal 11 (SIGSEGV) at 0x00002e50 (code=1)
F/libc    (  365): Fatal signal 11 (SIGSEGV) at 0x00003dec (code=1)
F/libc    (  361): Fatal signal 11 (SIGSEGV) at 0x00001ea0 (code=1)
F/libc    (  359): Fatal signal 11 (SIGSEGV) at 0x00005db0 (code=1)
F/libc    (  373): Fatal signal 11 (SIGSEGV) at 0x00001e84 (code=1)
F/libc    (  371): Fatal signal 11 (SIGSEGV) at 0x00002e50 (code=1)
F/libc    (  374): Fatal signal 11 (SIGSEGV) at 0x00003dec (code=1)
F/libc    (  370): Fatal signal 11 (SIGSEGV) at 0x00001ea0 (code=1)
F/libc    (  368): Fatal signal 11 (SIGSEGV) at 0x00005db0 (code=1)
F/libc    (  382): Fatal signal 11 (SIGSEGV) at 0x00001e84 (code=1)
F/libc    (  380): Fatal signal 11 (SIGSEGV) at 0x00002e50 (code=1)
F/libc    (  383): Fatal signal 11 (SIGSEGV) at 0x00003dec (code=1)
F/libc    (  379): Fatal signal 11 (SIGSEGV) at 0x00001ea0 (code=1)
F/libc    (  377): Fatal signal 11 (SIGSEGV) at 0x00005db0 (code=1)
F/libc    (  391): Fatal signal 11 (SIGSEGV) at 0x00001e84 (code=1)
F/libc    (  389): Fatal signal 11 (SIGSEGV) at 0x00002e50 (code=1)
F/libc    (  392): Fatal signal 11 (SIGSEGV) at 0x00003dec (code=1)
F/libc    (  388): Fatal signal 11 (SIGSEGV) at 0x00001ea0 (code=1)
F/libc    (  386): Fatal signal 11 (SIGSEGV) at 0x00005db0 (code=1)
F/libc    (  400): Fatal signal 11 (SIGSEGV) at 0x00001e84 (code=1)
F/libc    (  401): Fatal signal 11 (SIGSEGV) at 0x00003dec (code=1)
F/libc    (  398): Fatal signal 11 (SIGSEGV) at 0x00002e50 (code=1)
F/libc    (  397): Fatal signal 11 (SIGSEGV) at 0x00001ea0 (code=1)
F/libc    (  395): Fatal signal 11 (SIGSEGV) at 0x00005db0 (code=1)
F/libc    (  409): Fatal signal 11 (SIGSEGV) at 0x00001e84 (code=1)
F/libc    (  407): Fatal signal 11 (SIGSEGV) at 0x00002e50 (code=1)
F/libc    (  410): Fatal signal 11 (SIGSEGV) at 0x00003dec (code=1)
F/libc    (  406): Fatal signal 11 (SIGSEGV) at 0x00001ea0 (code=1)
F/libc    (  404): Fatal signal 11 (SIGSEGV) at 0x00005db0 (code=1)
I did a quick Google search on fatal signal 11 and SIGSEGV. Apparently it is called a segmentation fault. The cpu is trying to access memory it can't address. I saw one instance on stack overflow that was caused by allocating too much memory or the process ran out of memory to use. Don't know what that means for this case though.
Okay, I fixed that error. Now here's where it's getting stuck:
Code:
I/cm      (  126): Welcome to Android 4.1.2 / CyanogenMod-10-20130316-UNOFFICIAL-iconvmu
I/cm      (  127):                                                 _
I/cm      (  128):  __ __ _ ___  _ _  __  ___  __ _ _  _  _  __  __))
I/cm      (  129): ((_ \(/'((_( ((\( ((_)((_( (('((\( ((`1( ((_)((_(
I/cm      (  130):      ))                 _))
I/cm      (  131):
I/rmt_storage(  171): rmt_storage user app start.. ignoring cmd line parameters
I/rmt_storage(  171): rmt_storage open success
E/ThermalDaemon(  172): Thermal daemon started
E/ThermalDaemon(  172): Threshold 0 Action[0] : none
E/ThermalDaemon(  172): Threshold 1 Action[0] : none
E/ThermalDaemon(  172): Threshold 2 Action[0] : none
E/ThermalDaemon(  172): Threshold 0 Action Info[0] : 768000.000000
E/ThermalDaemon(  172): Threshold 1 Action Info[0] : 368640.000000
E/ThermalDaemon(  172): Threshold 2 Action Info[0] : 245760.000000
E/ThermalDaemon(  172): Number of cpus :1
I/rmt_storage(  171): 3 supported partitions found
E/ThermalDaemon(  172): No rules to monitor sensor 'XO_THERM' disabled: 0 num_thresholds: 0
E/ThermalDaemon(  172): No rules to monitor sensor 'XO_THERM_GPS' disabled: 0 num_thresholds: 0
E/ThermalDaemon(  172): No rules to monitor sensor 'POP_MEM_TZ' disabled: 0 num_thresholds: 0
I/rmt_storage(  171): rmt_storage open event: handle=1
I/rmt_storage(  171): Opened /boot/modem_fs1
I/rmt_storage(  171): rmt_storage events processing done
I/rmt_storage(  171): rmt_storage send user data event
I/rmt_storage(  171): rmt_storage client thread started
I/rmt_storage(  171): rmt_storage open event: handle=2
I/rmt_storage(  171): Opened /boot/modem_fs2
I/rmt_storage(  171): rmt_storage write event
I/rmt_storage(  171): rmt_storage fop(1): bytes transferred = 3145216
I/rmt_storage(  171): rmt_storage fop(1): bytes transferred = 512
boot.img
No the icon00 defconfig is correct kernel config for the Reverb. Its in the README-Kernel file from the official Samsung source fyi. I use that config to compile the reverb kernel.
I was incorrect to say that, the icon00 config is actually the reason we have a boot(looping) CM10 now!
Unfortunately I'm going back to college today, so my free time will likely be nonexistant yet again.
However, we've made a ton of progress. We now have a (almost) booting ROM and a github, so others can definitely pick up where I left off.
The updated repos can be found at
https://github.com/Jimmyk422/android_device_samsung_iconvmu_jb
and
https://github.com/Jimmyk422/android_vendor_samsung_iconvmu_jb
What I know so far:
It's not giving me a dmesg (which is probably the next step). I get
Code:
klogctl: Operation not permitted
When I try to run it. I can't find how to fix that, but I think once it's fixed we can start finding out why it's getting stuck.
Here's the last logcat I got
Code:
I/cm      (  126): Welcome to Android 4.1.2 / CyanogenMod-10-20130317-UNOFFICIAL-iconvmu
I/cm      (  127):                                                 _
I/cm      (  130):      ))                 _))
I/cm      (  131):
It's stopping at rmt_storage. I have no idea why.
That's all I know. Hopefully Interloper can explore a little bit if he has some free time.
I'm going to check the permissions between CynagenMod and stock Kernel after work today.
Thanks for all your work Jimmy and Interloper!
So, since Jimmy422 has more class than I do, I'll try and get some stuff working too. If I saw the logs correctly we just need some minor hacking to the miracle.c libs no one has ever heard of. News at 11. Wait, where's the files?
Look back for the _jb repos. I couldn't get it to update the old repos. And the last log is the most recent (no libc or thermald errors). If you need the zip of the most recent build I can upload that too.
Will do, but no thanks on the upload. It'll be faster to build it.
