Shabbypenguin
Extreme Android User
hey interloper i know its not much but #2A342294DB4942823 should help towards buying a reverb now that they are on sale
haha like i said its not much, i emptied my entire paypal balance![]()
If I could get $50, I would buy it from VirginMobile at the sale price.
DO YOU HEAR THAT COMMUNITY? I am willing to put up HALF the money to help YOU, just cuz I love Android. But, the offer is only good through the night. Sorry it came so late and after I spent $600 on tires, $900 at the vet, $700 on a buildbox and my wife is dying of cancer. (I'm kidding about the perspective, but not the facts)
Cheers and OUT!:cheers:
I'll give you $50 towards it
PM me
The price went up to $150 and it's still out of stock. If, by some strange chance, that changes we'll talk.
I'll trade you my reverb for your victory
I'd really like to keep the Victory. Thanks for the offer though.
What if you get a used one on ebay for $100 instead?
No problem, whatever you want to do man. I was serious though. If you ever need help getting a new device, I'll gladly donate $50 to you.
Always great full for the massive amount of help and work the OUDHS team does for us Android users ;-)
<7>[ 3.699798] msmrtc_tod_proc_result: 03/20/2013 18:47:38 (02)
<6>[ 3.699829] rs30000048 rs30000048.262144: setting system clock to 2013-03-20 18:47:38 UTC (1363805258)
<4>[ 3.700042] Warning: unable to open an initial console.
<6>[ 3.700317] Freeing init memory: 212K
<3>[ 3.700958] init: normal boot mode, is_battchg=0
<3>[ 3.703521] init: /init.qcom.rc: 466: invalid command '/system/bin/log'
<3>[ 3.703643] init: /init.qcom.rc: 567: ignored duplicate definition of service 'sdcard'
<3>[ 3.703674] init: /init.qcom.rc: 580: ignored duplicate definition of service 'ftm_ptt'
<3>[ 3.703765] init: /init.target.rc: 56: invalid command 'user'
<3>[ 3.703796] init: /init.target.rc: 57: invalid command 'group'
<4>[ 3.704101] init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead.
<6>[ 3.735198] EXT4-fs (mmcblk0p17): mounted filesystem with ordered data mode. Opts: barrier=1
<3>[ 3.736297] init: Device Encryption status is (0)!!
<3>[ 3.736328] init: [disk_config] :::: fsck -> /dev/block/mmcblk0p19 (ext4):::::
<3>[ 3.742797] init: [disk_config] ext_check -> /system/bin/e2fsck -v -y /dev/block/mmcblk0p19
<3>[ 3.807891] init: [disk_config] ext_check ->ok
<6>[ 3.817993] EXT4-fs (mmcblk0p19): mounted filesystem with ordered data mode. Opts: discard,noauto_da_alloc,journal_async_commit
<6>[ 3.826965] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: barrier=1
<3>[ 3.827056] init: [disk_config] :::: fsck -> /dev/block/mmcblk0p18 (ext4):::::
<3>[ 3.827087] init: [disk_config] ext_check -> /system/bin/e2fsck -v -y /dev/block/mmcblk0p18
<3>[ 3.839202] init: [disk_config] ext_check -> ok
<6>[ 3.848999] EXT4-fs (mmcblk0p18): mounted filesystem with ordered data mode. Opts: barrier=1
<3>[ 3.849090] init: [disk_config] :::: fsck -> /dev/block/mmcblk0p14 (ext4):::::
<3>[ 3.849121] init: [disk_config] ext_check -> /system/bin/e2fsck -v -y /dev/block/mmcblk0p14
<3>[ 3.858062] init: [disk_config] ext_check -> ok
<6>[ 3.867736] EXT4-fs (mmcblk0p14): mounted filesystem with ordered data mode. Opts: barrier=1
<3>[ 3.870056] init: [disk_config] :::: fsck -> /dev/block/mmcblk0p20 (ext4):::::
<3>[ 3.870086] init: [disk_config] ext_check -> /system/bin/e2fsck -v -y /dev/block/mmcblk0p20
<3>[ 3.884490] init: [disk_config] Error ::execute :: Error in (Status 8)
<3>[ 3.884490] init: [disk_config] Error ::* failed to check -1
<3>[ 3.885192] EXT4-fs (mmcblk0p20): VFS: Can't find ext4 filesystem
<6>[ 3.899291] EXT4-fs (mmcblk0p17): re-mounted. Opts: barrier=1
<3>[ 3.944366] init: cannot find '/system/bin/icd', disabling 'icd'
<3>[ 3.944610] init: cannot find '/system/bin/sec-ril', disabling 'secril-daemon'
<3>[ 3.944641] init: cannot find '/system/bin/ddexe', disabling 'DR-daemon'
<3>[ 3.944641] init: cannot find '/system/bin/kiesexe', disabling 'KIES-daemon'
<3>[ 3.944671] init: cannot find '/system/bin/smdexe', disabling 'SMD-daemon'
<3>[ 3.945953] init: cannot find '/system/bin/samsungpowersoundplay', disabling 'powersnd'
<3>[ 3.946380] init: cannot find '/system/bin/dmbserver', disabling 'dmb'
<3>[ 3.946777] init: cannot find '/system/bin/at_distributor', disabling 'at_distributor'
<3>[ 3.955871] init: cannot find '/system/bin/qmiproxy', disabling 'qmiproxy'
<3>[ 3.955902] init: cannot find '/system/bin/qmuxd', disabling 'qmuxd'
<3>[ 3.955932] init: cannot find '/system/bin/vpncstarter', disabling 'vpncstarter'
<3>[ 4.109436] FTK Charger Unpluged
<3>[ 4.115539] FTK Force Calibration
<6>[ 4.155303] warning: `dttexe' uses 32-bit capabilities (legacy support in use)
<6>[ 4.319427] VPNClient built on Mar 17 2013 02:30:37
<3>[ 4.898376] init: cannot find '/system/bin/netmgrd', disabling 'netmgrd'
<3>[ 4.898437] init: cannot find '/system/bin/wiperiface', disabling 'wiperiface'
<3>[ 4.898651] init: cannot find '/system/bin/ATFWD-daemon', disabling 'atfwd'
<3>[ 4.898681] init: cannot find '/system/bin/mm-pp-daemon', disabling 'ppd'
<3>[ 4.898834] init: service 'console' requires console
what partition is mmcblk0p20 supposed to be?
[collecting table information]
recovery filesystem table
0 '/tmp' 'ramdisk' '(null)' '(null)' 0
1 '/boot' 'emmc' '/dev/block/mmcblk0p8' '(null)' 0
2 '/system' 'ext4' '/dev/block/mmcblk0p17' '(null)' 0
3 '/data' 'ext4' '/dev/block/mmcblk0p19' '(null)' -16384
4 '/cache' 'ext4' '/dev/block/mmcblk0p18' '(null)' 0
5 '/recovery' 'emmc' '/dev/block/mmcblk0p15' '(null)' 0
6 '/sdcard' 'vfat' '/dev/block/mmcblk1p1' '/dev/block/mmcblk1' 0
7 '/efs' 'ext4' '/dev/block/mmcblk0p14' '(null)' 0
8 '/modem' 'emmc' '/dev/block/mmcblk0p6' '(null)' 0
9 '/modem_bkp' 'emmc' '/dev/block/mmcblk0p21' '(null)' 0
That's a good question. I don't think it's anything.
Although it's showing up in proc/partitions...
for some reason your init's are trying to mount it as an ext4 partition, if its in mount on stock then you should be able to see what the proper mounting options are![]()
app_123@android:/ $ cat proc/partitions
major minor #blocks name
179 0 3866624 mmcblk0
179 1 106495 mmcblk0p1
179 2 500 mmcblk0p2
179 3 3596 mmcblk0p3
179 4 1 mmcblk0p4
179 5 8192 mmcblk0p5
179 6 20480 mmcblk0p6
179 7 4096 mmcblk0p7
179 8 8192 mmcblk0p8
179 9 8192 mmcblk0p9
179 10 4096 mmcblk0p10
179 11 4096 mmcblk0p11
179 12 4096 mmcblk0p12
179 13 8192 mmcblk0p13
179 14 8192 mmcblk0p14
179 15 8192 mmcblk0p15
179 16 8192 mmcblk0p16
179 17 819200 mmcblk0p17
179 18 573440 mmcblk0p18
179 19 2187264 mmcblk0p19
179 20 53248 mmcblk0p20
179 21 20480 mmcblk0p21
179 22 4096 mmcblk0p22
179 32 1955840 mmcblk1
179 33 1954816 mmcblk1p1
app_123@android:/ $ mount
rootfs / rootfs ro,relatime 0 0
tmpfs /dev tmpfs rw,nosuid,relatime,mode=755 0 0
devpts /dev/pts devpts rw,relatime,mode=600 0 0
proc /proc proc rw,relatime 0 0
sysfs /sys sysfs rw,relatime 0 0
none /acct cgroup rw,relatime,cpuacct 0 0
tmpfs /mnt/asec tmpfs rw,relatime,mode=755,gid=1000 0 0
tmpfs /mnt/obb tmpfs rw,relatime,mode=755,gid=1000 0 0
none /dev/cpuctl cgroup rw,relatime,cpu 0 0
/dev/block/mmcblk0p17 /system ext4 ro,relatime,user_xattr,barrier=1,data=ordered 0 0
/dev/block/mmcblk0p19 /data ext4 rw,nosuid,nodev,noatime,user_xattr,barrier=1,journal_async_commit,data=ordered,noauto_da_alloc,discard 0 0
/dev/block/mmcblk0p13 /persist ext4 rw,nosuid,nodev,relatime,user_xattr,barrier=1,data=ordered 0 0
/dev/block/mmcblk0p18 /cache ext4 rw,nosuid,nodev,relatime,user_xattr,barrier=1,data=ordered 0 0
/dev/block/mmcblk0p14 /efs ext4 rw,nosuid,nodev,relatime,user_xattr,barrier=1,data=ordered 0 0
/dev/fuse /mnt/sdcard fuse rw,nosuid,nodev,noexec,relatime,user_id=1023,group_id=1023,default_permissions,allow_other 0 0
/dev/block/vold/179:33 /mnt/extSdCard vfat rw,dirsync,nosuid,nodev,noexec,noatime,nodiratime,uid=1000,gid=1023,fmask=0002,dmask=0002,allow_utime=0020,codepage=cp437,iocharset=iso8859-1,shortname=mixed,utf8,errors=remount-ro 0 0
