Hi mafm1965. In Gmail for Android you get a sending message in a kind of popup near the bottom of the screen when you send an email not a message in the notification bar. Then using the menu on the top left of the app you can check your sent email folder just to be really sure. I haven't had any problems yet and I've been using Gmail on phones for years.
I'm sure you can get that with a ringtones app..
I installed an Iphone ringtone app that tells me when I receive an email or message..
It may have the sent sound..
Also try Googling for an answer..
