Root over clock to 1.6?
outkast25
i want to over clock my epic even more. its at 1200 ...... i have the mixup kernel... how can i oc even faster? I read this kernel should oc to 1.3 or 1.6 but i cant figure out how to get 1.6 ive done all the reading and asking questions i could.....thx
I did a quick search.....have you looked into Baked Snack?
http://www.bakedsnackshack.com/downloads-epic.html
I've never tried it myself. i also saw something about Cyanogen Mod. For Froyo being OC'd like that.
I javennt read about baked snack. Is tht just the kernel. I don't really want a custom Rom. And you said oc on froyo? I thought you could not oc 2.2?
I think Baked snack is a full rom, and they have diff. versions of the kernel. About the other thing, yeah, i dunno.... i thought i saw some blurb when i did a quick search, but i didn't check it out.
On second look, it looks like it might hae been done a Samsung Vibrant...
http://www.addictivetips.com/mobile/overclock-samsung-galaxy-s-to-1-6-ghz-blows-off-competition/
So far it's running pretty snappy. One issue I noticed is when I turn the screen on the clock is behind? It takes a few moments for it to catch up. I have set CPU set to peformance and to under clock when screen is off. Anyone know what time delay issue could be ?
To attempt to get a little more juice out of your phone, open your SD card to the root an delete the entire android folder. When you re-boot it will be regenerated, and possible ease up some of your battery drain.
Ah ok, i'll give that a try.... thanks!
