talonpunk831
What overclock speed are u guys running and how is it?
I'm running 710 when the screen's on, and it seems pretty damn smooth and responsive to me
Ditto! 710 (max) 245 (min) with screen on. 480 (max) and 245 (min) screen off, using OC Widget from the market (free). Things seem to work well.
^ this. It works flawlessly for me.
Sent from my HERO200 using Tapatalk
I tried Zen but for me the updater wouldn't work, installations kept failing then leaving me in recovery menu. Also I hated how all the icons had ******ed looking boxes around them.
Im rooted with Fresh 2.3.3 and Overclock widget only has the settings up to 528 with screen on. am i missing something with setting it to 710?
yeah I can't get mine up past 528 either
i got mine to work, and i set it to 710, but it doesnt display more than 528.
you have to define the frequencies you want to use inside the widget. one you do that and save, you should be fine, but its still displayes 528 for me and not 710. Though 710 is a max and may not show up unless under load, i just want to be sure its done correctly.
Oh, ok I already did this. I didn't realize it wouldn't show more than 528 if it was running hotter than that.
well thats the thing. i dont know if it should show more than 528 even though it may be running 710. i was hoping for some clarification by the more experienced users.
Can you overclock with Fresh
2.1.3?
What's a good link for over and under clicking the hero? I like the idea of better speed AND battery life...
