Doogald, thank you for the link. It worked perfectly. I was able to overclock last night and have it at 768/480. I followed the instructions and the phone froze when I hit I think 787. So it rebooted and then I turned it down to 768 and it's cranking along. It's much quicker now.
Now if I flash another rom do I need to overclock again or will that be included in any new ROM's that I flash?
my feelings on setcpu and overclocking are mixed. most of the froyo roms now and fast enough without it. I always enjoyed the faster speeds at first, but usually things started to get laggy after a while.
I am using SetCPU chiefly to underclock when the phone's display is off (and when the battery gets low.) I do get better battery life that way. If you do use SetCPU, by the way, resist the temptation to install its widget. That will really make your phone lag.
So far I haven't had any lag issues with SetCpu.
How exactly should I be underclocking for when the phone is off?
Hope I'm not thread jacking here, just thought of a setcpu related question and thought I'd pose it here. If you don't have "Set on Boot" checked, does that mean that setcpu will not start overclocking or using your profiles until you actually open the setcpu program?
Thanks doogald! Yeah, I try not going too nuts with OCing. I also use it mainly for underclocking sleep profiles. Was just curious if setcpu would start running at all if I didn't open it myself.
