Root Overclocking Help.
VsUK
Trying to push my cpu passed 791mhz that my superpad 2, flytouch 3 currently runs at, but every time i try a took, nothing seems to be happening. I used 1 tool that used to push my speed up to 812mhz on Tims 5e but now im on the latest 6a & it wont.
Here is the report.
Code:
 Android release: 2.2
Device model: DISCO10
Manufacturer: unknown
Mod  version:
Developer ID:
Device nickname: disco10
CPU tuner version:  3.3.10
Language: en
Userlevel: 3
Beta mode: false
Multicore:  ch.amana.android.cputuner.hw.CpuHandler
Installed as system app: false
CPU governors: [not  available]
CPU frequencies: [-2147483648] (no available frequencies)
Min  scaling frequency: -2147483648
Max scaling frequency: -2147483648
Current  governor: not available
Current frequency: -2147483648
Current power  usage: -2147483648
Average power usage: 0
CapabilityChecker:
rooted:  Yes
Governor: No governors found
  Governor: read: failure - write:  failure
  Up Threshold: read: not checked - write: not checked
   DownThreshold: read: not checked - write: not checked
CPU paths:
Anyone know of something i can use to counteract this?
