Root Overclocking Questions.
chacen.droid
So tonight after the bootloader disappointment, I decieded to try overclocking for the first time. I am pleased to say I'm OC'd to 1.35 and running ULV as we speak... and running very stable i might add! I am more than pleased! :D
I do however have a couple things i need clarification on.
1. Temperature, what's average? How hot is too hot?
2. In regards to battery life, is there a big difference (any) between say 1.1 ULV & 1.3 ULV?
3. Any other things to watch out for with OCing?
Thanks alot guys! Too bad about custom recovery not coming true, but I'm definitely not dumping my X anytime soon!
1. ive been told that anything up to 107 is ok,
2. I would guess this is just going to depend on your phone, test it out yourself :)
3. Try playing some games and watch for lag or complete crashing
Thanks for the quick reply dude!
Question 2 is a little unclear, i guess a better question might be; Do both clock speed and voltage effect battery life or is it just one or the other?
ah, my guess from using quickclock is that less speed will improve battery. but as long as you are undervolted you should be saving battery anyway
