65 is the min voltage?...I am at 35 through Overclock. should i go higher?... btw 1250 on the other end.There's overclocking, which gets you more speed, smoother animations and decreased battery life.
Then there's undervolting, which gets you better battery life.
If you do both, higher top speed with a lower voltage, you get the best of both worlds. Every phone is different tho. Some phones achieve faster speeds or lower voltages (or both).
I'm overclocked with jRummy's Overclock and use QuickClock to establish lower voltage profiles. Both are apps worth buying. QuickClock is adding a lot of new features like stress testing. I'm running 1250 @ 65.
If you're only going to get one, I'd go with QC. If you tap the menu button, the help file tells how to use it. I find that bumping up the min VSEL voltage it detects by 2 or 3 will save you some time getting it stable.
