Help overheating and task killer
So I'm pretty new to the android world and not very tech savvy...I have an HTC evo 4G and it seems get up to 105 degrees all the time...the back gets hot and kinda makes me wonder if its overheating or am I worried for nothin? I have androsensor to tell me the temp and whatnot i just dont know whats an ok temp and whats not...
Also is task killer good or bad...I've used it then took it off and read both sides of the fence...idk my phone dies at an ungodly rate anyway so should I just uninstall it and leave it alone or ???
Thanks for reading :-)
Welcome to the Forums!
I don't know much about CPU heat but I'm sure there are many people here who could help.
As for Task Killer. I've been told to not use one. Android works in such a way that when programs are "active" they aren't really using resources unless you are using them for a task at the time. So, you could have 3 or 4 applications "running" in the background but they're not realistically using the CPU. They are what they called "cached" which is basically a fancy way to say they've been bookmarked for use at a later time. In some cases using a Task Killer can hurt your battery life because Android is re-opening tasks it needs to run over and over.
Anyway, hope this helps somewhat. Welcome to the Forums!
Task killers do more harm than good, here's why:
I develop Android apps so I though I'd explain why a task killer isn't needed on an Android system.
Activities
Android apps use activites to preform tasks. For example, if you use a file manager to send a picture via email, the file manager calls the send activity within an email app, passes the file name to it and the email app sends the picture.. not the file manager. This will result in seeing the email app as "running" even though the user didn't actually launch that email app.
Smaller apps
Using activites helps developers design smaller apps. A file manager app that contains every bit of code needed to do everything a file manager does would likely be so large that no one would want to install it. Developers know that an android phone more than likely has an email app so there is no need for the developer to include email code in his/her file manager to send a picture when he/she can call an activity in an existing email app to do the job. This results in a smaller file manager app since there is no need to include email code or any other code for an activity that can be done via an app that is already present on the phone. This also alleviates redundant code. When you install an app outside of the android market, also known as sideloading, the file manager app calls the package installer (already present in Android) to install the requested app.
Running apps vs. cached apps
The "Manage Applications" list included in many android devices lists running apps as well as cached apps. Cached apps don't use any CPU or battery, they're cached so they will load faster the next time you need them. Killing cached apps results in those apps requiring more time to load the next time they are launched.
System management
By default, every android application runs in its own Linux process. Android starts the process when any of the application
The EVO 4G has been known to over heat and power cycle or just stay off. usualy above 103 degrees. Seems the other posters have answered the task killers pretty well.
Thanks to everyone for the advice! Def not gonna use the task killer...as for over heating should I take it to the store and get a new one or just try to keep it cool?
Thats kind of a coin toss.
I had a launch day EVO and it never rebooted due to heat.
The only time it did reboot on me is when i was using navigation and talking on BT headset. When it came back up i resumed the call with no problems. Then went back to navigation and still no reboot.
Others have had numerous reboots. I guess if it becomes an issue take it in.
The techs are supposed to turn on all RF radios, and run Neocore for 30 minutes. IF it reboots then they are supposed to warranty it.
