ebrandwein
and the phone promptly overheated a few minutes later. Sigh....
No joy. Still getting very hot for no apparent reason.
Ok. This weekend I did a full wipe of the phone and the sd card. I have since reloaded everything. I have even tried deliberately over stressing the phone. Nothing. Nice and cool. I now believe that the whole problem is the apps and data that the previous version of the os installed on the SD card. Kit Kat has apparently changed the way sd cards can be used to such a degree that old apps and data can really cause trouble. It was a pia to have to reload everything but, so far, it all seems good.
Sorry for your trouble, but thanks for circling back with the solution (and I know the pain of doing a full reset).Ok. This weekend I did a full wipe of the phone and the sd card. I have since reloaded everything.
True. I would look into some vehicle mounts for phones. They can come with suction cups or clips to clip into a vent. I use the kind with clips in my truck and absolutely love it. Plus if you have working air conditioning, it will run that much cooler. If you are in the U.S., check them out at Newegg.
Usually overheating like that is caused by runaway apps that are overtaxing the processor. You can download battery monitoring apps like GSAM and usually pinpoint the offending app or process that is causing the phone to overheat. Just a suggestion if you run into the issue in the future![]()
ebrandwein;[URL="tel:6591208" said:6591208[/URL]]I was keeping an eye on running apps before the reformat. I don't think it was a runaway app so much as the way Kit Kat now works with SD cards. Removing apps and data that previously resided on the sd card and running them from main memory (Non-SD) is really the only significant change between my setup now and what it was before the reformat.
I have a feeling that after the OS upgrade, some apps or data remained in SD card folders that are now off limits to apps in Kit Kat. It makes sense to me that the machine might be fighting with itself if this was the case. That would explain the overheating and the battery drain. Things may have been happening in the background with legacy data on the SD card that shouldn't have been there. For a discussion of the new android SD card rules, see:
KitKat and SD cards — what's fixed, what's broken and what's misunderstood | Android Central
I have made several rather paranoid attempts to overtax the phone in the last few days to try to get it to overheat like it did before. So far, nothing I've thrown at it has tripped it up.
