Hello. Is it possible to have my own background on the phone? If I do the resolution get's f......
What should resolution should I use? Is there possible to have just one picture on the home screen that is locked?
i use my own and the resolution is best around 960x800 pixels, your home screen pic will be your lock screen picture as a rule, Rather than using the phones wallpaper option which makes you crop it all the time use the app 'wall paper set and save' Wallpaper Set And Save v1.1.008 Application for Android | Tools
