i purchased a 4gb superpad2 touchfly3 enhanced black edition from merimobiles.com and love it except id like to install a custom rom and understand i cant yet, but im also unable to download anything because it says no sd card found, but if i go through mypad i can see and explore the sd card, i have tried multiple reformatting options on it and restored to factory settings as well, also my wifi will randomly disconnect and say the network is not in range and cant connect. Please someone help me out with this issue i know its software based just need help fixing it, thanks!
JaySynn
Hi
Jay how are you, on the sd-card when you say you can see it in mypad have you downloaded anything to your windows computer and to the sd-card like angrybirds apk,or anything that takes your fancy and then tried to download to your tablet?try that 1st and then you will know if you have a sd-card problem? or a tablet problem.
On your wifi iv'e sold so many tablets flytouch 2.1,2.2 disco,and now these po41,and iv'e come across wifi issues with a few and most go back to the router,yes iv'e heard well it can't be everything else works ok,but it
as always been the router, the biggest router problem is the linksey's,best way to find out is go try someone elses wifi different from your own wifi supplier,if it works there ok,then it's the router,you need to go into your router manufacture settings?make sure its got latest drivers?it's not on a common channel used by everyone who as routers living around you?
that your wifi settings are correct
channel i've set them all to channel 6,but you can use 9,11
wan setup-MTU size = approx 1500 inbites,
vpi = 0,
vci = 40,
DHCP = ON,
wpa/wp2,psk mix mode,
wpa =tkip+AES,
SEND SYS LOG= DIABLED
FIREWALL= OUTBOUND= ENABLE ACTION ALWAYS
INBOUND= ENABLE ALWAYS
let me know i had a few problems myself most with dropping youtube,also your router may need updated drivers if you have not updated for a while go to your router manufacture website and see if you have latest drivers installed
EASIEST WAY TO FIND OUT IF IT IS YOUR ROUTER PROBLEM GO TO A FRIENDS OR FAMILY MEMBER TRY THERE'S AND MAKE SURE IT'S NOT THE SAME internet COMPANY AS YOURS?
also do a web search wifi connection problems not for android just a web
search on wifi connection problems,it's a very common problem on windows,phones,tablets etc
