P500 with Parrot
revjames
Hi there
Just found this forum and it looks an informative and helpful place so thought I'd drop in and ask a question if thats OK:
I recently got a P500 Optimus one on a T Mobile contract. I use the phone a lot in my work so installed a Parrot CK3100 in my car - system was easy to fit and works seamlessly with my old phone - a Nokia 2720.
My problem is that the LG will pair and connect and sync no problem at all. It will even autoconnect the second time you get in the car but after that it seems to 'forget'. There does not seem to be a way to make it autoconnect with the parrot and to have to manually select 'settings/wireless/bluetooth settings/ Parrot/Connect' every time I get in the car is a right pain to say the least.
I'm sure there is a solution out there somewhere? or did I get the wrong phone?
Regards
James
