P5110 4.2.2 allshare cast not found?
everfor
i bought the netgear ptv3000 and i have been told it will support S3 and tab 2 10.1. When i check in my tablet i can't find allshare cast sw and i couldn't find where to download it. My device samsung galaxy tab 2 p5110 android 4.2.2. When i done google search some links says android 4.3 version i.e cm10.2 will support the miracast/allshare cast? is it true? should i upgrade 4.3? please advise
It looks like the OP is willing to install a non-stock firmware (eg Cyanogen Mod 4.3).
I hear lots of good stuff about CM, so if you are willing to install it, then by all means give it a try.
Keep in mind that there is always some element of risk when flashing a new firmware and take care to make sure the firmware you are going to install is compatible with your device.
Any idea which version will support the allshare cast to ptv3000?
Bit disappointment, i have installed 4.3 CyanogenMod 10.2 official nightly build in p5110 and i can't find the miracast feature or allshare cast.. Did i installed the right version?
