JesseBrown23
Member
I had tried rooting a while back with a tutorial for rooting the smaller version of the Tab2 and it said it all worked and was successful and i downloaded root checker and it said I have no root. Root apps don't work. I even have CWM recovery.
I'm running 4.1.1 and when I try to update it says "Your device has been modified. Software updates are not available."
Can someone point me in the right direction to either like completely wiping my Tab2 of CWM and all (i tried factory reset and it didn't remove CWM) or how to root the Tab2 P5113 running 4.1.1
