Root Package file is invalid? Tried Everything. HELP!
Dr. Dank
I cant download any app from the play store. whether on wifi or 3g, no luck.
I searched a lot and tried uninstalling updates, clearing caches, re-adding the google account, and nothing has worked. Even changed the privacy setting "automatic restore" to off...
Please help me out here. Am I missing something? :(
Maybe reflash the ROM with complete wipes?
Clear data for Google services framework. Wipe cache and dalvik. You should be good after that. GO PATS
Edit* Oops. Looks like you fixed it. In the future. ^^^^^^°That should work for you ^^^
