Broomfundel
Hi there,
Jumped straight to Glaxo 1.61 when I got back from holiday, and now am not sure if this issue is from I7500XEFJB2 , Glaxo 1.61 or just me being lucky.
I used the market to install as many of my old apps as I could. However some like Night Clock did not apear. Not a problem, I installed them from the old .apk files. Which worked as it should.
Today however, I select the file, hit install once the Application Manager asks, then hit Install again in the Package Installer. The screen gives me a grey bar with Package Installer of about half a second, then goes straight back to the install/cancel screen.
I have removed the last half a dozen apps I had installed. (This bit worked fine.)
I have installed apps from the Market Direct, (This seems to work.)
I heve deleted every cache and run the sync command.
I have disabled the Unknown Sources and re-enabled it.
I have tried the fix package permissions from the recovery menu.
None of these seem to have had any impact on the problem. Less than 24 hours in to this set-up, so I am happy to go home / wipe and start again If I need to.
Has anyone had this? Am I best to go to stock 1.6? or should Glaxo be fine where this is concerned.
Any pointers would be greatly appreciated.
Thanks
Thanks
