D
Deleted User
Guest
I have a major problem with my droid. I've had it since late November and love it. It's rooted and I've been using Bugless Beast since 1.5. I've updated everytime Pete puts out a new one. However, I tried switching to Ultimate Droid, it sucks, and CyanogenMod 6.0.0., but what I didn't realize at the time, was that it wasn't the Droid version, but the D/S version. Afterwards I did a nandroid restore but the installer doesn't work. The market will download apps and then when it tries to install, it gets stuck. Also trying to just install from the SD card doesn't work. I've tried doing factory resets, going back to BB 0.3, everything but an MDS Lite flashing (i don't remember the correct name but whatever). I can get some apps back from the nandroid restores but Titanium Backup isn't working because I can't install any apps. I also can't uninstall apps
. Sometimes, for reasons unknown, it will allow a couple apps to install or uninstall, but apps that I had used Pete's Apps2SD (non-hack but Froyo based) to move to the SD card won't open from my launcher and says, "application is not installed". Idk what to do to fix this. Anyone else have a similar problem with "Package Installer"? One final thing that seems to be related is when I go to "Manage Applications" it never finishes calculating the apps memory use. It just keeps saying "Calculating..."
