Root pacman rom hybrid properties....
thIsgUy20
i've been using pacman for about a week or two and today i was changing my screen around. i got it finally how i want it to look and i think to top the look off i want to make the navigation bar transparent. Now im on tablet mode you know where the status bar is at the bottom and it has the navigation keys so i went to hybrid propreties and went to buzz launcher to change the navigation bar to transparent but the settings are too big. it's like when i scroll to colors it doesn't show the colors part. but if i turn my phone side ways i can click it but its to big so when i do it side ways i can't click change to this color or whatever it says. like i can choose the color but i can't choose to apply it because the buttons arent on the screen........ ill take a screenshot for you all so you can see
sorry about the long message i was trying to figure out how to explain it. & if i misspelled a lot its because i turned auto correct off.
nope that didnt work. i took the dpi down as far as it could go then rebooted didn't work then i took the dpi as high as it could go. still no luck
it did change the size but for some reason it still doing the same thing it was doing earlier
turning the phone in lanscape was the first thing i tried. the second picture is what happens when it is in lanscape mode. i can use the slider the get transparent but i can't apply it because it's to big and doesn't show the buttons. i tried going in landscape changing the transparency then switch back to portrait but that doesn't work either
