Help Palm motion not working for screen capture
henjus
Palm motion is not working for screen capture, i had try reset n chg the setup but no luck. Any idea why? Pls help :)
Firstly, and not as obvious as it reads, is it switched on ?
Menu (left softkey)>Settings>Controls>Palm motion>Capture screen.
I find it very difficult to do too; much easier to press home and power key at the same time. :)
Are you using a live wallpaper? I've noticed mine doesn't work either, I'm using one of the Parallax live wallpapers...I think that's a problem. For now, I'm ok with using the spen, just pull it out and press the nib anywhere on the screen for at least a second.
