Wlliam. Member Aug 5, 2010 #2 Your country is not supported. Even if you can get the APK file it wont work. Where are you located?
E EightSixteen Newbie Aug 6, 2010 #5 Pandora works perfectly for me and I am from the UK , downloaded it straight from the marketplace too. I deleted it and reinstalled there with no problems. Give the dev a wee email to see if he can look into it for you.
