Root Pandora on NexTheme ESE81 R2
Branndon
The rom runs amazing. Low temp, fast etc. But I can't get pandora to install for ANYTHING. I have 3 different versions floating around on my SD card. None will install, nor will it install from the market.
I deleted EVERY file on the phone (not SD card) which had pandora in the name, and tried to reinstall and reboot, nothing.
Any suggestions? I leave for an 8 hour road trip tomorrow and want to have it working.
Also running Nextheme ESE82 R2 and totally loving it. I installed Pandora from the market a couple of days ago and it is phenomenal. I have had no problems installing or using. I put in one song and everything it has thrown at me I have given thumbs up. I installed the rom from DM root, but I did 2 complete formats of DATA, CACHE, SYSTEM before installing. Did you do those wipes?
Yes I'm using root explorer to delete not only the apk files but all the temporary data files too. I've been running this rom for weeks and this is the only problem I'm having. Yes I did all the wipes. I'm pretty sure anyway.
Just to compare:
I have Pandora version 6, app size 1.05 in settings-applications-manage apps.
With Root Explorer, in /data/apps com.pandora.android.apk - 16-Apr-10 size 660273
How about yours?
Pandora.apk 11 FEB 10 Size: 667877
com.pandora.android.apk 12 Nov 09 Size: 643983
com.pandora.android.apk 26 Jan 10 Size: 643983
com.pandora.android.apk 25 Mar 10 Size: 660273
I've also tried restoring from a titanium backup, installing just the app SAYS it installs ok, but it's never there, if I install app + data, I get an error and it won't install.
Have you tried going into Settings/Applications/Manage applications. Then tap Menu/Filter select All and look for it in there. If it is there, uninstall it
