Rippsnorter
Running CTmod 3.68, booted into recovery and created 1gb sd partition. rebooted and internal storage isn't showing any increase in storage, but sd storage is showing the decrease of 1gb. any ideas?
Yeah I used cwm to make the partition. I mounted it, but every time I mount it, reboot, then reboot again into recovery to check it it doesn't show that it's mounted. Haven't made any adjustments to koumamod or anything
ah yeah, just needed to set koumamod mounting mode to data. rebooted to recovery, mounted the partition and its working! thanks!
koumamod does not work for cyanogenmod. it works with half ass rom and ctmodThis is my first post ever so I hope that I do this right. I'm currently running Hroark's CM7 Port for prevail. I've read all of the threads concerning partitioning as well as every other thread in Prevail-all things root and I've managed to set up a partition but I'm having a hard time setting up swap. I would love a step by step tut for kumamod 1.7 and also sdparter. Thank you very much to all who have contributed to the vast wealth of knowledge that this site contains.
swapon dev/block/mmcblk0p3
