I am using Cyanogenmod 7 and App2SD (as explained here). I want to move EVERYTHING to the SD card (including data) and use ext4. How should I partition the card (using Gparted) to have it working properly?
I tried doing it with Clockworkmod but it is very limited (only 1 partition+swap?) and does not ask me if it should be ext4.
What is the best number, type and size of partitions for 4gb and 8gb card?
