filipino808
Member
I have a 16gb and a 4gb , what are good size partitions for these cards?
it wasnt foe sd cards thoughHi! I did an online research to help you with your query and I stumble upon this site. I hope you can find solution from this link. Good luck.
Why are you partitioning it in the first place? The Lucid comes with 1GB of internal storage, which should be more then any normal user would need for apps and that should be the only reason to partition an SD card.I have a 16gb and a 4gb , what are good size partitions for these cards?
is it even necessary to partition to install roms?Why are you partitioning it in the first place? The Lucid comes with 1GB of internal storage, which should be more then any normal user would need for apps and that should be the only reason to partition an SD card.
nope, not at all.
It was a option for old devices like the Ascend and Optimus C/M that had nadda for internal storage.![]()
