Root Partitioning SD Card for EXT3 > 512MB
started rooting and ran out of empty cd (for gparted), so gave a try with this minitool and fortunately it worked :p
my app2sd is already less than half size after installing many apps :D
Is there any good cache cleaner app? before rooting I used app2sd to clean cache
Hope it continues to work for you. It's not the best choice, but if it works, then I don't think anybody can complain. I know a few people who have used it and had no problems. Fair play to them!
Cache Cleaner should do what you want it to do. :)
