Root partitions "Need a favor"
chevanlol360
Android Expert
ok i need one of you guys to reboot into your stock recovery since you guys dont have cwm yet. First download this file and place it on your sdcard file
if you dont know the actions/buttons to press to boot into recovery please plug in your hydro into your computer and go to settings Developer Options and make sure USB Debugging is enabled.
you must have adb shell installed to do this.
open up command prompt and type the following
Adb shell
Su
reboot recovery
after that your device will automatically reboot into recovery.
ones it in recovery you should see an option like "Apply updater from sdcard" select it by scrolling up and down with the volume key and press the power button to enter it. go down to the lastlogtest.zip and select it. select yes install. now it wont install and you should get some kind of error. go back to the main screen of recovery and also wipe cache. once done reboot your device and use a file explorer and go to /cache/recovery/last_log copy it to your sd card and upload it to anywhere and send me the link. this is a way to see if your recovery shows what partitions is what which will come in handy in the future for development of roms cwm etc in the future.
so how is the work going on cwm, i sure hope all involved are making progress,i really like the hydro,would be great to see cwm,and some roms start rooling out,anyway was just curious ...good luck
hey Chev I killed my ultra with milk and its dead so I'm over here now. Hope to see a Megatron on this side. And Maybe Bob OC Kernal. Thanks for helping on this side.
Hey chev is there any word on progress of a new recovery coming. :D
My cwm Master just went M.I.A cant get a hold of him. I'll keep trying, i dont think i'll port megatron here. I plan to mpve on the the sequent before summer this year so they will most likely get. Depending on the development of the phone maybe by summer i'll make a decision to bring megatron over here or not. ICS is a new OS for me. Gotta study up on it.
