ZINGALOPE Newbie Aug 7, 2010 #1 pattern code any way to bypass this code. wife locked it. she has about 20 email forgot which one she used. pliz only incoming calls can be recive.
S SamsungVibrant Android Expert Sep 14, 2010 #2 i think if you enter it like 10 times, then you can do a factory reset, but that does you no good.
melll Android Enthusiast Sep 14, 2010 #3 SamsungVibrant said: i think if you enter it like 10 times, then you can do a factory reset, but that does you no good. Click to expand... It will if it helps him bypass the lock pattern
