pattern problem
mashriq
hello every body i have GT- n7000 SAMSUNG NOTE i faced problem that i cant see pattern lock option after pressing power buttion and when i hold power button i dont see phone option its directly turn off and i also take factroy restore but the problem as well plz help me i cant access the pattern screen while i press power bitton only screen of
That is strange. What do you see when you press the power button? Do you see anything when you press the Home button? Are you able to see the pattern vaguely or not all? I find myself not being able to see my Pattern lock when I am outside in the sunlight and it's usually due to having the brightness to low, so I just go stand under shade to swipe the pattern. I hope this helps! If not provide more details on what you see when you press the Power or Home button. Regards,
