pc bookmarks to hero phone ?
B UR SELF
hi chaps
i wanna move all my bookmarks from pc to hero to be able to smoothly
use them on my hero
is any chance to do that ???
if yes can u tell me which folder shall i put them ???
cheers
If you are running Android 2.1 then just download HTC Sync 3 (the newer version of Sync). It allows you to sync your bookmarks over from Explorer
