AngelicCore
Hi,
I am using gigabyte 3x power motherboard which should give the USB ports 3x the normal power (0.5->1.5 for USB2 and 0.9->2.7 Amps for USB3)
I am also using the USB3 charging cable that came with the device.
I am sensing that it is still slower than the 2 Amps stock charger.
It should be able to charge just as fast considering it is connected to the USB3 Case Port connected to the USB3 Port on the motherboard with that feature using the USB3 cable that came with the device. Also if it makes any difference the driver for on/off charging is installed.
Is there a method or an app that shows me how much current my device is currently sucking in?
Thanks.
Thanks.
