Root PC sync prob
havc
Hi,
I am using Galaxy Y S5360 and I am facing a problem in synchronizing music and videos form my computer to mobile .I use the software "kies " (soft by Samsung ) .
The prob is that if I add a folder to kies library then it do not updates if I add some video to the same folder after adding the folder to kies lib .
Thanks in advance
