androidnewbie5
Hi everyone,
although I know my way around Windows computers I am a complete novice when it comes to Android and Smart Phones. I have a 4 days old LG L55c Android 2.3.4 smart phone and am working my way through it.
Lists and Notes:
I have installed EverNote, Astrid, etc. and am not totally satisfied. I am looking for an app that I can sync to some equivalent on my own Windows PC (or import a comma sep file) without needing to go through the web or Google. That is by direct usb cable. Is that possible? Does everything I use on the phone have to also be in the cloud? I am still leery of intrusting my stuff to the cloud.
Calendar:
Same question, Would like a calendar for my phone that I could sync with my PC via usb cable without passing first through the cloud. Most calendars on the PC import and export to standard ics files but I cannot find an Android calendar app that can import ics files.
There must be many others who would like something like this. Does it exist?
Thank you.
Lists and Notes:
Calendar:
Thank you.
