ROMs pcd venture android 2.3.5 virgin mobile cm port
im trying to build cyanogen mod to the pcd venture and i dont know where to start :(
There are lots of guides on the web for this, but as a start I would start with a supported device and use it as a guide. It's not going to be easy to port it over to your phone, but should be doable.
Could you help me setup Debian to compile cm sources?
I'm still using Ubuntu 10.04
You could use what ever you want, but need to make sure the tools are installed. It's just over my head, but I might be able to help, though it would take lots of time.
Start with the "building Android from source" sites you find from a web search and we'll go from there.
Would anybody be willing to show how awesome there rom building skills are by building cm for this device?
